twrerctr
Jun 03, 2017Initiate
Orbi installation - firmware update - dead router
Followed quik start guide, everything connected, connected the app, changed the SSID and password, then was give option to update the firm ware. Said it would take about 3 minutes, then after a few ...
twrerctr
I pressed for 15-20 seconds, there was no change to the green light. After your post I tried pressing for longer, finger got tired after 2.5 minutes. Still no change to green light.
How would I go about a forcing a firmware update without being able to access the router page?
st_shaw
Jun 04, 2017Master
When you insert a paperclip into the reset hole, you hold down the button until the green power LED starts flashing amber. It shouldn't take 2.5 minutes. Maybe the firmware got corrupted during the upgrade.
This page describes how to force a firmware upload using TFTP. You do not need to access the router webpage. I have done this to correct corrupt firmware, but have not needed to do this with Orbi.
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
