cenastyle's avatar
Mar 23, 2018
Orbi Internet Issues...
Bought and installed new Orbi system yesterday. Everything worked great, with the exception I was getting roughly 1/2 the speed I was with my Xfinity gateway. Fast forward to today, I’ve had to restart it 7 times already. It keeps telling me I’m connected to the Orbi network, but have no internet access. If I disconnect and reconnect to my Xfinity gateway, I have internet. This is the second Netgear router I’ve had issues with. In fact, the reason I bought this is because my Nighthawk X8 R8500 died in less than 2 years. Firmware is all up to date on the Orbi. Contemplating Linksys Velop or Eero at this point.
  • FURRYe38's avatar
    Whats the Mfr and model# of the ISP modem/gateway?
    If this has a built in router, you need to do the following, either have the ISP put the modem into full transparent bridge mode, or if it can't do this, use the modems DMZ for the IP address the Orbi router gets from the modem. Input this IP address into the modems DMZ and disable all wireless and uPnP features.
    If you don't want to run the Orbi system as a main host router, you can leave the modem in router mode then use the Orbi system in AP mode. This will disable most of the Orbi router features however. Just the MESH wifi system will be available.
    • cenastyle's avatar
      cenastyle
      Tutor
      It is already in bridge mode. I believe it’s an Arris, but I can check later when I get back home.
      • FURRYe38's avatar
        Please let us know the model when you can.
        Also swap out ethernet cables between modem as router as well. CAT6 is recommended. Shorest length possible.
        What Speeds UP and Down do you pay for?
        What FW version is currently loaded on the router?
        Any wifi neighbors near by? If so, how many and what channels are they using?
        When you loose internet, do you still access to the routers web page?
  • When you say you have the latest firmware are you trusting the Orbi to tell you you're up to date ? because it lies.  The latest firmware that I'm aware of is :  2.1.2.18.   My Orbi was on an older firmware and the "check for update" feature was telling me I was up to date.   I had to manually update to 2.2.18 and all of my issues went away.
      • ChewyWest's avatar
        ChewyWest
        Well that's interesting.  I had disconnects, etc. using 2.0.1.4.   When I upgraded my FW to 2.2.18 everything settled down.  I am hardwired to a Satalite Orbi which I don't think was supported in 2.0.14 and I think the FW update solved that issue.  I've been running fine for a week now with 2.2.18.  Just my experience.
  • FURRYe38's avatar
    Lets see what version is currently on the OP router first. This maybe an FW issue or something else. Rather not jump to any conclusions...
    • bent_wookie's avatar
      bent_wookie
      Star
      Once he's done checking his cables, maybe check NASA for recent solar flare activity. Could be so many things unrelated to buggy Netgear firmware.
      • FURRYe38's avatar
        Buggy FW hasn't been ruled out either.
      cenastyle
      Tutor
      Sorry, just got home. Gateway is a Cisco DPC3941T is bridge mode. My Orbi app is telling me I have firmware version 2.0.0.56. It is telling me there are no updates available, but maybe that’s not the case? With my old Nighthawk and Cisco gateway, I was typically getting 170-190 Mbps. I haven’t seen anything over 90 Mbps with the Orbi. Ethernet cable has been swapped out, as well. My WiFi list pulls up almost 15 different networks for my neighbors. No idea how to check what channels they’re using.
      • FURRYe38's avatar
        The beta is for RBR50 and RBK50 models. All other models are still waiting...soon.
        Find you a wifi scanner for your mobile device and see if you can tell what channels there using. Would be best to find 1, 6 or 11 with minimal use of others if possible.
        Be sure when speed testing that your using a wired ethernet PC connected to the router for more accurate results.
