Doctorold
Apr 30, 2017Star
Orbi IOS app won't connect to network
I recently discovered the Orbi app after having had my network setup for some time. But the app won't connect to the wifi network I've created. I'm wondering if it's because the name of the network...
gerstein
May 04, 2017Initiate
I am having the same issue. Set up the network and it is working fine but when I try to connect with the app (either the Orbi app or the the Netgear Genie app) it just times ut. Verified I am on the wifi network from the Orbi and still does not work. Suggestions?
paperboy
Dec 21, 2017Initiate
