snickydootx
May 19, 2018Aspirant
Orbi Isn't Finding Modem, Network not visible on devices
Attempting to connect for the first time and having no luck connecting to the modem. I get the Orbi Mini Router RBR40 and the RBW30 Orbi Wall Plug Satellite to sync up, blue ring on the satellite...
May 21, 2018Guru - Experienced User
Did you power OFF the modem for 1 minuted then back on, then power ON the router?
Swap LAN cables between the orbi router and modem?
What ISP are you with?
Try MAC Clone of the router to the modem?
snickydootx
May 21, 2018Aspirant
Yes, I powered everything off for 5 minutes, then brought everything up the way the instructions said to. First the modem, then the router, then the satellite.
No, I haven't tried to swap LAN cables.
I have Xfinity for my ISP.
I don't know what a MAC clone is.
