snickydootx
May 19, 2018Aspirant
Orbi Isn't Finding Modem, Network not visible on devices
Attempting to connect for the first time and having no luck connecting to the modem. I get the Orbi Mini Router RBR40 and the RBW30 Orbi Wall Plug Satellite to sync up, blue ring on the satellite...
May 21, 2018Guru - Experienced User
Do you get internet connection with a PC/laptop wired cirectly to the modem?
Try swapping cable between the modem and router...
IF this fails, you may have a bad Orbi router....
