walkerx
Jul 24, 2018Guide
Orbi Issues with V2.1.4.16
 Hi,
 I am a UK Sky fibre-pro user using the Sky Q Hub with the Orbi system. I have configured the router for AP mode and connected the WAN port to my switch and have reserved an ip address for it, m...
Jul 24, 2018Guru - Experienced User
Disable Daisy chain since satellites are connected wired, not wireless. Daisy chain is for wireless back haul.
What is the Mfr and model# of the switch?
walkerx
Jul 24, 2018Guide
i followed the instructions and thought it meant if using the daisy-chain topology to enable the daisy-chain back-haul in the settings
I disabled that and the minute I did and it started rebooting the devices I lost my dns, yet this should not happen as I'm on wired connection and my dns and gateway on pc are set to my main router not the orbi system - if i reboot my tp-link ap (needed as my alarm system has problems with the orbi network as they are not seperated) this doesn't cause me to loose dns, so why would the orbi's
my current switch is zyxel gs1900-24e, uk (setup today due to the issues having) - it was previously a tp-link TL-SG1008D which had the same issues
my setup now is as follows
sky q hub -> samknows whitebox -> 24 port switch -> orbi router (ap mode)
the 24 port switch is then off to two other switches where the satellites are connected at the moment.
previously the setup was as follows
hg612 modem -> pfsense -> samknows whitebox -> 8 port switch -> orbi (with switch then off to two other switches for the satellites)
