rwood24
May 25, 2018Aspirant
Orbi kills AT&T DVR
Orbi kills AT&T DVR. Hours on the phone with Netgear and AT&T, no solution. Previous posts, same subject do not work. All other internet services working, love the Orbi, but can't keep it if my DVR ...
May 25, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem?
Might try this, set ISP modem back to router mode. Use the Modems DMZ for the Orbi router in router mode. Input the IP address the Orbi router gets from the ISP modem and put this into the modems DMZ. Set a IP address reservation for the Orbi IP address ON the modem/router so it doesn't change. Then see what happens.
If not, try putting the Orbi into AP modem with the ISP modem in router mode and check...
Your DVR might need direct contact with the ISP modem rather then another 2ndary router...
