ARCFISH
Apr 30, 2020Aspirant
ORBI Lag Spikes while Gaming
Using an ORBI RBR40 Router + 2 Satellites
The system works great for everyone but my son, who gets crushed playing online games due to lag spikes.
The Orbi router is hooked up to an Arris Internet Modem provided by ISP.
The Orbi router replaces a Sagecom router (non mesh) that had no lag spike issues.
There are no double NAT issues. (only 1 private IP address)
The problem persists on Wifi or Ethernet connetions, and applies to all devices connected to the network. Video streaming works fine. It is only a noticable issues for game play.
I spoke with an extremely patient and helpful tech support agent who adjusted some things on my router to increase our overall network speed.
He even created a 'service' that enabled TCP port forwarding from the Gaming PC in question to the Gaming Server (@ Blizzard).
The problem still persists. I am beginning to think that Lag Spikes are inherent in the Mesh architecture. If anyone has resolved a problem like this. I'd appreciate any pointers. Thanks!
What is the model# of the ISP modem the NG router is connected too?
Is the Gaming PC wired or wireless connected to the Orbi system?
Are there other internet devices getting internet services while the gaming is going on?
- ARCFISHAspirant
Router Model = RBR40
Firmware = V2.3.5.32
Internet Modem = Arris TM1602
Lag happens when using ethernet or WiFi
Yes - there are other services in use during gaming. I think we tested with no other servies running, but I may try that again to see what happens.
- robstallAspirant
I've the exact same issue (right down to the frustrated son). Currently I'm running pinging the router from a wireless device. About every 30 seconds, the ping will spike from <5ms to >2000ms. This happens when either wired or wireless and I might not have issues for days at a time and then the issue will start in again. I can't pin down just what triggers it and it is really only noticable when gaming.
