davidcamm's avatar
davidcamm
Follower
Nov 18, 2020
Orbi LBR20-100EUS NETGEAR LTE Router 4G LTE Advanced WiFi Router (LBR20)
Hi
I have an Orbi Mesh WIFI system with 5 Satelites and was wondering two things.
1. If I buy the Orbi Router with LTE 4g, model LBR20 will my existing Orbi Satelites be compatible or do I need new ones? if so which model?
2. Will this LBR20 LTE Model work anywhere in the world with an LTE Sim Card (Country Specific) or are there other models for other countries? ( I am thinking what Bands will the LTE work within?
I need a free of these Kits in the EU and some in the uSA.
Thanks
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi davidcamm
    Welcome to NETGEAR Community!
    You can sync Orbi AC Satellites such as RBS50, RBS50Y, RBS40, RBS40V, RBW30 or RBS20 to the LBR20 router.
    NETGEAR has several different SKUs of the LBR20 Orbi 4G LTE Tri-band WiFi Router products and each product has a specific set of bands that is supports based on the region that it is purchased in.
    Please check KB link below for the list of supported bands:
    What cellular bands are supported by LBR20?
    Blanca
    Community Team​​​​​​​
