k9kids
Sep 29, 2016Guide
Orbi light indicators
My Orbi base and satellite don't show any indications the system is working. Is there a feature that needs to be turned on? Would prefer something I can look at to know all is well. Setup in AP ...
- Sep 29, 2016
hi K9kids
with the orbi system working you will see no lights , which is a good thing if the devices are in open areas , the only light you will see is the power light indicating the system is on , if there is an issue you will see different colored lights depending on the situation
yes its a bit counter intuitive but seeing nothing is a good thing for the orbi once its started up and connected correctly
pete
