rodneymiller12's avatar
Mar 02, 2018
Orbi loses internet connection with Comcast
Having issues with My Netgear Orbi and connectivity to my Comcast modem  At least once a day my orbi loses its internet connection with the modem. I have the modem setup in bridge mode, my router and satellites are up on the latest firmware.  I have noticed that if I take my modem out of bridge mode and shutdown my orbi and use comcast to serve as the wifi router I never lose connection so I know the issue is not with the modem.  Any suggestions where to go to next?  I am not super familiar with all the network settings I can tweak so any and all help is welcomed.
Thanks
  • FURRYe38's avatar
    Whats the Mfr and model# of the ISP modem? Built in router by chance?
    Swap ethernet cables between the modem and router. CAT6 recommended.
    Thanks
  • this is a known issue documented in this post: https://community.netgear.com/t5/Orbi/What-you-can-expect-with-your-Orbi-system/m-p/1503034#M23257
    good luck - so far the only solution seems to be putting a smart outlet / timer on your satellite(s) to reboot them once every 24 hours (I'm not joking) or rolling back the firmware (but I still see people saying they experience the same issues on the older firmware)
    see this guy: https://community.netgear.com/t5/Orbi/Orbi-satellite-dropping-connection/m-p/1512445#M24230
     Don't listen to the netgear shills on these forums that blame the user and give you the same bs about trying to disable beamforming/mimo or moving the satellites closer to the router.  Waste of time until netgear releases a fix.
    • t_k's avatar
      t_k
      Luminary
      By shills, he's specifically referring to FURRYe38, who just trolls this forum divving our useless comments.
