tonypap
Apr 09, 2018Tutor
ORBI LOSES/DROPS INTERNET CONNECTION
RBR50 keeps losing internet connection. All devices are conntected to the orbi WiFi but there is no internet connection. The internet connection is dropped mulitple times per day. I currently have...
aprairie
Apr 13, 2018Initiate
I had a similiar issue on a few of my devices (including a Windows PC that spent majority of the day on my work network) and tried a number of different things before finally hitting on what appears to resolve the issue for me. Your mileage may vary. I am in router mode and manually selected ALL 3 DNS. This was the key part. Previously i set just two of the three and still had problems. This weekend I updated with Cloudflare as #1 and then Google as #2 and #3 and so far (knock on wood) I have not had the problem.
Why it would matter that i provided 3 DNS addresses vs. 2 i don't know, but it did.
Good luck.
Npran
Aug 03, 2018Guide
Thank you,
Just bought an orbi, updated the firmware first thing. Did a clean setup and went about 2 hours before I started experiencing these drops.
Reset firmware, fought with getting it reconfigured only to experience the same thing.
Had mu-mimo enabled, beamforming, ipv6 and default DNS. Disabled ipv6 with no success, disabled mu-mimo and changed to the recommended DNS. I guess we'll see but it's been slightly better. I need this to work... I have gigabit internet, and google wifi was only giving me 120mbps. So far early tests with the orbi have be at 530 Mbps so there is great potential if the internet doesn't drop.
- NpranAug 04, 2018Guide
scratch that, still experiencing drops.
- FURRYe38Aug 04, 2018Guru - Experienced User
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Try disabling the following:
MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).You may need to factory reset the router and satellite and set up from scratch as a last resort:
Npran wrote:
Thank you,
Had mu-mimo enabled, beamforming, ipv6 and default DNS. Disabled ipv6 with no success, disabled mu-mimo and changed to the recommended DNS. I guess we'll see but it's been slightly better. I need this to work... I have gigabit internet, and google wifi was only giving me 120mbps. So far early tests with the orbi have be at 530 Mbps so there is great potential if the internet doesn't drop.- NpranAug 04, 2018GuideWhat is the Mfr and model# of the IP modem the Orbi is connected too?
Actiontec T3200M
2000
40ft
Channel 6
Yes, about 11 other broadcasted ssid
All disabled currently. Also, I reduced the broadcast strength of 2.4 GHz to 50% and 5 GHz to 75%.
I have 5 Google home, two echo, Chromecast ultra, apple TV, Phillips hue with 17 lights, TV, ps3, ps4, Nintendo switch, Asus rp-a68u (bridge mode), two phones (iPhone and note) a tablet, two laptops (MacBook pro and windows 10) and wireless printer connected wirelessly.
Seems stable today, was up until 4 am configuring and signing reserved addresses to everything. Been using the smartphones intermittently, MacBook frequently and ps4 most part of the afternoon without a hitch.- FURRYe38Aug 04, 2018Guru - Experienced User
What happens if you turn of the all of the following?
5 Google home, two echo, Chromecast ultra, and Phillips hue with 17 lights
Actiontec T3200M
2000
40ft
Channel 6
