sirpots
Feb 21, 2018Follower
Orbi Losing CenturyLink PRISM TV signal
Hello All, I am currently using my Orbi System to get rid of the provided router CenturyLink. I have Gigabit Internet and TV. The Internet portion works great! I am running into a problem with th...
danstah
Apr 17, 2018Aspirant
It does have a router/modem however I currently have an asus router which I can connect directly to the fiber box (Not sure If I'd consider that a modem) without the need for the provided Technicolor modem/router thing. When I do this I need to enable vlan tagging for 201 and then turn on IGMP Snooping (Efficient multicast forwarding) and IGMP Proxy (Multicast Routing). See below picture for example (IGMP settings were not enabled in this picture but need to be for Prism TV to work).
It seems as though the IGMP Proxy is there within the Orbi settings but I'm not seeing anything about the Snooping which makes me wonder if that's why the OP is having issues.
Apr 17, 2018Guru - Experienced User
Ok, well, I know there is mention of managed switches used with Orbi systems that seems to cause problems. A user just posted today that disabling IGMP on the switch seems to help resolve the connection issue between the router and satllite when a managed switch is in between. I know this is not related to this post, hoeever maybe something to look at.
Also having a router in between the ISP service and the Orbi router or any other router will cause problems, Double nat condition is not recommended. So reason for asking. DMZ on the ISP modem or ONT can help with this if the modem can't be fully bridged or use the modem router as the NAT router and change the Orbi to AP mode.
danstah wrote:It does have a router/modem however I currently have an asus router which I can connect directly to the fiber box (Not sure If I'd consider that a modem) without the need for the provided Technicolor modem/router thing. When I do this I need to enable vlan tagging for 201 and then turn on IGMP Snooping (Efficient multicast forwarding) and IGMP Proxy (Multicast Routing). See below picture for example (IGMP settings were not enabled in this picture but need to be for Prism TV to work).
- danstahApr 17, 2018Aspirant
Maybe I didn't explain well berfore my current setup. Also keep in mind I'm not the OP who was having issues. I don't have an Orbi at the moment.
For reference right now I have:
ONT > Asus Router (with the settings I talked about before)
See pic below (Not mine but it's the same one)
- I have read that you can set your ISP provided router device and set up a transparent bridge however I've tried with very little luck so I'm trying to avoid that stupid thing all together. The software interface is terrible.
- Am I right in thinking that IGMP snooping isn't possible on the Orbi?
- FURRYe38Apr 17, 2018Guru - Experienced User
I know this isn't in reference to the OP.
If you can't get the ISP modem/router in bridge, be sure to use it's DMZ for any router you have behind the modem. This will help with NAT issues. This would be all you need to do with the modem.
I don't believe Orbi supports IGMP. I don't have that kind of TV service. I have DISH with Hopper and 3 joeys. The Joeys are all wired up thru the Orbi system to the Hopper. Works well here for me.
Thanks for the advice. Using IPTV is a real pain.
