Escondido's avatar
Nov 28, 2017
Orbi losing packets
Hello,
I'm seeing packet losses with my Orbi.
I have the RBK53 (RBK50, boxed with two remote Orbi devices).
The Orbi is hardwired to my firewall.  Also hardwired to my firewall is a Linux computer.
Using the Linux computer, overnight I ran a ping test to 8.8.8.8.  In the morning, I had no packet loss.
At the same time I also ran the same ping test from two computers connected via WiFi to the Orbi:
1) Desktop with fast USB WiFi adapter (Connected to Orbi with 5 bars and 500+ mbps),
2) Older laptop with internal WiFi adapter (Connected to Orbi with 5 bars and 80+mbps).
In the morning, the ping test from the Linux computer had zero packet loss.  The desktop and laptop each had 1% packet loss.
Any ideas why this would be?  The 1% loss is fairly high.
    • Escondido's avatar
      Escondido
      Tutor
      Thanks DarrenM, I appreciate the info on the update firmware.
      I did see that others were still seeing packet drops with certain devices.  I'm seeing packets dropped with a desktop using a Belkin USB Wifi and a laptop using a built-in Wifi.
      But the new firmware is definitely worth a try - I am currently on V2.0.0.74.  If it works I'll report back.
        Escondido
        Tutor
        After a bit of struggle, I was able to update my RBR50 and two RBS50 units to the latest firmware V2.1.1.16.
        (Serious Netgear, if my RBR50/RBS50 units appears to be working well, why do I need to reboot the RBR50 in order for the updates to work properly?  And why do I need to manually update all the units?  This isn't junior league.)
        Anyway, the packet drops are still happening with the latest firmware V2.1.1.16.  Things look OK, then packet time will increase, then there is a loss of packets.  And as before, when I run the test at the same time from a hardwired system, I am not losing packets.
        The below ping tests were run at the same time:
        Test from Orbi system
        Reply from 8.8.8.8: bytes=32 time=34ms TTL=252
        Reply from 8.8.8.8: bytes=32 time=31ms TTL=252
        Reply from 8.8.8.8: bytes=32 time=160ms TTL=252
        Reply from 8.8.8.8: bytes=32 time=36ms TTL=252
        Request timed out.
        Request timed out.
        Reply from 8.8.8.8: bytes=32 time=30ms TTL=252
        Reply from 8.8.8.8: bytes=32 time=32ms TTL=252
        Test from hardwired system
        64 bytes from 8.8.8.8: icmp_seq=23 ttl=253 time=28.9 ms
        64 bytes from 8.8.8.8: icmp_seq=24 ttl=253 time=28.8 ms
        64 bytes from 8.8.8.8: icmp_seq=25 ttl=253 time=29.3 ms
        64 bytes from 8.8.8.8: icmp_seq=26 ttl=253 time=30.2 ms
        64 bytes from 8.8.8.8: icmp_seq=27 ttl=253 time=30.3 ms
        64 bytes from 8.8.8.8: icmp_seq=28 ttl=253 time=28.7 ms
        64 bytes from 8.8.8.8: icmp_seq=29 ttl=253 time=29.6 ms
        64 bytes from 8.8.8.8: icmp_seq=30 ttl=253 time=33.6 ms
        64 bytes from 8.8.8.8: icmp_seq=31 ttl=253 time=30.7 ms
        64 bytes from 8.8.8.8: icmp_seq=32 ttl=253 time=28.7 ms
        64 bytes from 8.8.8.8: icmp_seq=33 ttl=253 time=29.3 ms
        So something is definitely wrong with the Orbi system where it is losing packets.
        Does anyone have any thoughts on how to fix this?  Thanks in advance.
