rdpjr57's avatar
rdpjr57
Orbi Mesh AX6000 account question
I have an existing Orbi system on an exisiting Netgear account. I want to put a new AX600 Orbi mesh at a new location. Can they both be on the same Netgear account or do they need to have seperate ac...
  • rdpjr57's avatar
    rdpjr57
    Apr 25, 2021
    I thank you. Had you done this the first time, directly, we both wouldn't have wasted time with extraneous texting and minimized the frustartion in searching out an answer to a problem.
