seachellemz
Jul 30, 2019Aspirant
Orbi Network in Multiple Locations (residences)
I have two separate residences where I have a deployed an Orbi Mesh Network in each. My question is how can I remotely manage/administer each of them using the app. Does this require that I set up two separate email accounts/logins to Netgear and switch back and forth between those two ID's or is there a more elegant way to handle this?
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Should be possible.
- ekhalilMasterYou can manage multiple products using the Orbi app.
Once you setup the first system, you can go to >> Home >> NEW SETUP and add the second system.
You can switch between the systems by selecting >> Home >> my products where you should see all your systems.- seachellemzAspirant
Awesome...very helpful. One follow-up. I currently have both networks already set up. I am in residence-2 and have connected the Orbi app to it. I am no longer in residence-1, but the Orbi was set up prior to my leaving there. So....both networks are up and running. Is there a way I can gain access to residence-1 given that I am remote from it and did not follow the steps you outlined in your response.
- ekhalilMaster
Have you used the same app to setup both systems?
Have you registered both systems using the same netgear account?
Now that you’re at residence 2, open the app and select the home sign on the top left corner, then select "your products" in the row just under the top Orbi sign.
Do you see your products there?
To enable remote management using the app, go to Settings. In the app for every system and enable Remote Management.
