rdpjr57
Apr 25, 2021Aspirant
Orbi Mesh AX6000 account question
I have an existing Orbi system on an exisiting Netgear account. I want to put a new AX600 Orbi mesh at a new location. Can they both be on the same Netgear account or do they need to have seperate ac...
- Apr 25, 2021
I thank you. Had you done this the first time, directly, we both wouldn't have wasted time with extraneous texting and minimized the frustartion in searching out an answer to a problem.
CrimpOn
Apr 25, 2021Guru - Experienced User
Is the goal to manage two Orbi systems from one Orbi "app"?
I believe the answer is, "Yes, you can."
rdpjr57
Thanks, but I'm looking for something more definitive than "I believe the answer....". Doesn't instill much confidence.
If someone truly knows the answer and what to expect when setting up the second system on the same account that would be outstanding.
- CrimpOnApr 25, 2021Guru - Experienced User
How about this post from 2019:
https://community.netgear.com/t5/Orbi/Orbi-Network-in-Multiple-Locations-residences/td-p/1780921
- rdpjr57Apr 25, 2021Aspirant
