Sparxycat's avatar
Sparxycat
Follower
Jul 31, 2023
Orbi mesh network and Netflix UK on Samsung tv
Hi all,
I'm having issues with netflix in the UK. My Samsung TV is connected via WiFi to my main router about 2m of open air between them.
Netflix is majorly struggling to play and when going on the fast.com webpage it struggles to get to 32mb whereas on speed test it gets up to my usual 72mb. It only appears to be netflix. All other streaming services (Disney, Amazon etc) all work perfectly fine with no issues.
Netflix network test gets me an nw-2-5 error on server 3 from netflix which is a WiFi issue but whatever I do, I can't fix it.
Has anyone had a similar issue or can anyone point me in the right direction?
Thanks in advance.
  • FURRYe38's avatar
    What model Orbi system do you have?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many RBS are deployed?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    What channel configurations are currently set on the router?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, Smart Parental Controls or Circle, Traffic Meter.
    https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/ORBI-SAMSUNG-TV-BT/m-p/1862739#M1346
  • michaelkenward's avatar
    michaelkenward
    32 Mbps is plenty fast enough for most streaming.
    Close enough for an Ethernet cable if the TV supports it.
