yuvismahi2's avatar
yuvismahi2
Follower
Jul 03, 2020
ORBI Mesh RBK53S Router + 2 Satellites
I bought the Costco bundle of the ORBI RBK53S system that came with the router and 2 Satellites and I find that it doesn't give me full coverage of my home. I need to add more Satellites for coverage but cannot seem to find them in stock anywhere. Any suggestions? I have a pretty large house with 4 floors and 6 bedrooms and need 1/2 more satellites. What would be the recommend and most cost efficient way to expand my orbi mesh network?
The few satellites that I could find were either for an older router or cost prohibitive where I could almost just by the Mesh 6 system for relatively the same price. If I did that, could i use that bundle with my 2 satellites from the RBK53S system?
  • CrimpOn's avatar
    CrimpOn
    For a definitive answer, I would post in the forum devoted to the AX products:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    From what I recall, the answer is, "Orbi WiFi5 satellites can be connected to the AX system only over ethernet. The WiFi backhaul systems are totally different."  So, if you have ethernet cables in the house running to locations where these satellites will be located, you can.  But, if the system needs to use WiFi backhaul, then no.
  • FURRYe38's avatar
