MKC1298
Jul 08, 2020Aspirant
Orbi Mesh Router
I am looking to exchnage out my Optimum Router with an Orbi Mesh Router... Just not sure if it will work. Looking for any advice. Thank you
More information is required, such as the specific model of Optimum device.
Orbi WiFi routers do not include cable or fiber connections. They require a cable modem or a fiber ONT.
So, if the Optimum is a combination unit which includes the ISP media connection, you either have to purchase a replacement or keep the device and perhaps put it into "modem only" mode. (often called "bridge" or "passthrough" mode).
- MKC1298Aspirant
Thank you for responding, I have an opitmum Saagemcom router and an Arris TM1602 modem. I am looking ofr better bandwidth in my home. Opitmum has been terrible and I was recommndd to going with an Oribi Mesh Router. I just wan to make sure I order the right item to give me what I need,
https://community.netgear.com/t5/Orbi/Find-Your-Orbi-With-the-NEW-Orbi-Product-Selector/m-p/1907267/highlight/true#M91216
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Systems
