Qaisoon's avatar
Qaisoon
Orbi mesh routers
Hi everyone,i bought Orbi router but its power adapter indicate in its sticker it works on 100/110v but in my home the power outlet are 220v. I heard from other website it will work but iam not sure.. please help to confirm rhat.. thank you
  • FURRYe38's avatar
    IF you don't see 110/240v on the power adapter sticker, then you'll need to get a dual or universal voltage adpater for the Orbi system.
    • Mstrbig's avatar
      Mstrbig
      Master
      You can purchase an inexpensive travel adapter from several vendors that will work. I think I paid $14US for my kit. Can do 120-240 and 240-120.
      • Qaisoon's avatar
        Qaisoon
        I did try to power an old router with orbi adapter nothing happen to the adapter realy and the old Hewai router powerd on noramally
