taperanger
Apr 24, 2018Initiate
Orbi Mesh Setup Based In Guest House - Will Satelites Cover Main House?
I am moving into a house that has a detached guest unit. I want to setup an Orbi with 3 satellites. I want my internet connection and modem to be based in this guess unit so I can use the wired conne...
Apr 24, 2018Guru - Experienced User
Possibly will work. You would have to test it out. Distances between router and satellite should be about 30 feet minimum, depending upon building materials as well.
- taperangerJun 17, 2018Initiate
Just following up on this in case anyone else is interested in knowing.
This worked perfectly. Good 5ghz connections to each satelite and full 120Mbit coverage throughout 3,000 sf home.
Router is in detached guest unit with first satelite approximately 45-50 feet away through 3 walls.
Only been a month but very impressed with this system so far.
- FURRYe38Jun 18, 2018Guru - Experienced User
Thanks for letting us know. Glad its' working.
Enjoy. :smileywink:
