mrm18
May 14, 2020Tutor
Orbi Mesh system question - need another satellite ?
I live in a 3 story home. The main two levels is around 2100Sq feet. The basement (finished area) is about 425sq feet. I set up the RBR50 on the main level at one end of the house (that is where my modem is). I put the satillte (RBS50) on the 2nd floor, opposit side of the house. Things are working well. What I've noticed is that it seems I sometimes lose connection in the baseement. The finished area of the basement is the opposit side from the Router (more than 30 ft). However, when I do a speed check I get great speed. If I were to get another RBS50 for the basement would that help? Or is this just something that happens? I don't want to spend money (these aren't cheep) if it really isn't going to help much.
Thank you
- plemansGuru - Experienced UserTry testing it temporarily. Move the upstairs one down to the basement and see if the issues still happen. If they do, no it won't help. If it fixes them, then you might indeed benefit from another satellite.
Also, the RBS20, RBW30, RBS40, RBS40V, RBS50, RBS50Y are all compatible. You dont have to get just the RBS50.- mrm18Tutor
Thanks for the suggestion. Will have to time the test right as my wife is working from home and her office is upstairs? :-)
As to the other devices that are compatible, yes they aren't but aren't those slower? (the backhaul) those if I want speed I should stay with the 50? again thank you
They do have a slower backhaul. But it depends on what speeds you have and what you're doing. Its not going to slow the whole system, just the device connected to that satellite. Plus if you look at backhaul reviews, there wasn't a whole lot of drop off in speed.
https://www.smallnetbuilder.com/wireless/wireless-reviews/33125-wi-fi-system-roundup
So again, a lot depends on what you're doing and need for speed in the basement.
