Ramses17
Dec 29, 2018Follower
Orbi mini multiple ethernet
Need to connect 2 ethernet devices to router but it only has 1 connection available. Can I use an ethernet switch to expand?
Dec 29, 2018Guru - Experienced User
Be sure its a non managed, non smart and non green ethernet switch. You can use a managed switch if you disable ALL IGMP Protocols on the switch.
