Ramses17
Dec 29, 2018Follower
Orbi mini multiple ethernet
Need to connect 2 ethernet devices to router but it only has 1 connection available. Can I use an ethernet switch to expand?
Jake725
Dec 31, 2018Aspirant
Although the original Netgear Orbi was the first and, arguably. Each satellite has two Gigabit Ethernet ports, which you can use to plug in. It is the superior product and well worth paying the small amount extra prepaidgiftbalance.
