Yuyux
Apr 01, 2018Follower
Orbi Mini RBR20
I recently bought a Orbi mini pack (1 router and 1 satellite) from Costco. The model is RBR20 for the router and RBS20 for the satellite. Both with the latest firmware v2.0.0.64.
Great cover for my house, BUT..I have 2 separates SSID´s, both of them with the same name, but differences in signal strenght, and both can be seen on multiple devices (computer, cellphones, consoles).
Don´t know if this is OK, or is due to the firmware. I have understood that when you setup the network, you can see just one SSID.
Any one with the same problem??
1 Reply
There should be only one SSID after you complete the set up.
Where are you seeing these SSIDs?
Try a factory reset on both router and satellite then set up from scratch. Give a new SSID name. Make it different this time.
Does the same thing happen after setting up?
