JJ78633's avatar
JJ78633
Follower
Dec 22, 2016
Orbi mounting
I want to replace my unifi Ap,  can I mount the ORBI satellite upside down from the ceiling and secondly, can it be powered from an ethernet cable or does it require electrical connection?
thank you in advance
1 Reply
  • The Orbi is passivly cooled and having a "tower" provides a chimney effect and when I put my had over top its rather cool.  I would say you could mount is upside down but I don't know how you would do that since there are no keyholes or anything on the base of the unit. Also you need to think of how the antenna arrays are configured.  You may not get optimal wifi mounting it that way.
    One the power it's only though the power adapter there is no option for power over ethernet or useing ethernet as a backhaul.
