ORBIisJUNK
Jun 07, 2020Aspirant
Orbi network drops frequently and Satellite showing poor backhaul status
Hi, I have following setup RBR50 - Setup in basement RBS50-1 - Setup on the first floor which is above basement RBS50-2 - Setup on the second floor I have 500Mbps fiber optics line coming ...
Jun 08, 2020Guru - Experienced User
Basements are not recommended places for wifi routers. Concrete and steel foundations make it hard for wifi signals to travel. This maybe the main cause of your problems as you said you returned another system for same reasons. I would try to get the RBR up on the main floor.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
ORBIisJUNK
Jun 08, 2020Aspirant
Thank you for the response.
I had the same setup and it was working for last 6 months. What can be the reason of showing these issues suddenly?
I have 4 neighbors whose wifi I can see in the available networks.
Thanks,
CAH
- FURRYe38Jun 08, 2020Guru - Experienced User
Neighbors getting new wifi and causing more noise in the area. Possible working after you got a new system in however again began to fail due to placement in the basement. May work over a small period of time then begin to fail.
Try changing channels, Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
- TimmyTechTVJun 08, 2020TutorI'm having the same issues after the upgrade, also on 6/5. This .16 firmware is hot trash.
v16 is working for me.
Lets hope your other post will be more helpful:
