ORBIisJUNK
Jun 07, 2020Aspirant
Orbi network drops frequently and Satellite showing poor backhaul status
Hi, I have following setup RBR50 - Setup in basement RBS50-1 - Setup on the first floor which is above basement RBS50-2 - Setup on the second floor I have 500Mbps fiber optics line coming ...
ORBIisJUNK
Jun 08, 2020Aspirant
Thank you for the response.
I had the same setup and it was working for last 6 months. What can be the reason of showing these issues suddenly?
I have 4 neighbors whose wifi I can see in the available networks.
Thanks,
CAH
Jun 08, 2020Guru - Experienced User
Neighbors getting new wifi and causing more noise in the area. Possible working after you got a new system in however again began to fail due to placement in the basement. May work over a small period of time then begin to fail.
Try changing channels, Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
- TimmyTechTVJun 08, 2020TutorI'm having the same issues after the upgrade, also on 6/5. This .16 firmware is hot trash.
- FURRYe38Jun 08, 2020Guru - Experienced User
v16 is working for me.
Lets hope your other post will be more helpful:
TimmyTechTV wrote:
I'm having the same issues after the upgrade, also on 6/5. This .16 firmware is hot trash.- denniss82Jun 08, 2020Aspirant
I am having the same issue. just upgraded a few days ago.
Today the connection started dropping every 60 seconds. I have tried many things already, nothing works. I have gone back to two different firmwares , I have change the wan _lease, I have changed the wires, the power adapter, hard reset a couple of times. Nothing works, Keeps disconnecting about every minute or so.
Very frustrating.
Any other suggestions?
