Z190mn
Jan 05, 2020Tutor
orbi network turn of by dos attack
Hi, My orbi system turn off a view time's a week. When I take a look at the log file there is a dos attack standing on that time. I'm using: firmware version 2.3.5.30 orbi system RBR50 can s...
Z190mn
Feb 04, 2020Tutor
We have a modem from a dutch provider. And the modem is in bridge mode.
This is an URL to the specifications: https://nl.hardware.info/routers.9/compal-ch7465lg-zg-ziggo-connect-box.371250
There are a view other wifi connections nearby, but if I check this on my phone I count 4. So I don't think that's the problem.
Feb 04, 2020Guru - Experienced User
I would try this:
Configure the ISP modem back to router mode. Disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Z190mnFeb 09, 2020Tutor
I tried what you just said. This works good for a view days but after that the orbi had the same problem as before.
So I don't think that this is the good solution.
- FURRYe38Feb 10, 2020Guru - Experienced User
Have you changed the WiFi SSID and Pasword on the RBR?
Seems like something is going after the Orbi or there is some interferences.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925 - Z190mnMar 17, 2020Tutor
sorry for the delay.
I have tried but non of the things are working. :(
I had taked a look for all the channels what my neighbors but there are a view different channels.
- FURRYe38Mar 17, 2020Guru - Experienced User
You may want to contact NG support.
