denmig
Feb 11, 2017Tutor
Orbi network won't connect to the internet
Hello,
While installing my orbi, in the end the network is established but there is no internet connection. When I disconnected and put my old router (Netgear R6300 Smart WiFi Router) back up to the plate I have internet again. I have DSL from Frontier and the modem I use is a netgear broadband ADSL2+ . I'm sure there is a setting on the modem that I am probably unaware of that needs to be altered. Any advice or ideas ?
Many ISPs will only hand out 1 IP address. Therefore, try rebooting your modem after you hook up your Orbi to it. As a last resort, have the Orbi clone the MAC address of the R6300.
- denmigTutor
Thanks for the assistance. I wound up calling Netgear support and they were able to help me get it connected.
What did you have to do to make it work?
The answer might help someone who turns up here in the future with the same problem.
