Aviw
Jun 16, 2020Aspirant
ORBI never worked, lower the speed from 300 to 13!!!
Any idea how to make it work, or just go back to the grate Linksys?
Aviw
What Firmware version is currently loaded? Version V2.3.5.30
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Optimum ARRIS TM-1602
Is this speed test via wireless speed or wired? Wired!
I did not change any settings, this is how it works out-of-the-box (or actually dose not work)
Jun 16, 2020Guru - Experienced User
Do you enable Armor or Cicle by chance?
You might update to v16 on the RBS first then RBR lastly:
then factory reset and setup from scratch. Power OFF the ISP Modem for 30 seconds then back on. Be sure to not enable Access Controls, Armor, Circle, QoS or Traffic Meter. Speed Test with a wired connection soon as the setup wizard is completed with Ooklas installable speed test app. Test with a 2nd PC to be sure. Ensure the network adapter is getting 1000Mbps connection rates on the adapter.
- AviwJun 16, 2020Aspirant
I did all the above. now i'm getting 148/37 (WIRED) when i sepose to have 300. without the ORBI when connecting direct to modem I do get 300.
- FURRYe38Jun 16, 2020Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and RBR. CAT6 is recommended.
If the speeds are nothing near 300Mbps, something I would contact NG support about.
- AviwJun 17, 2020Aspirant
Thanks a lot for your help. It is a CAT6 cable and nothing near 300mbps.
I contact NG support and they ask me to pay $80 (on top of the over $400 I purchase it for) in order to make it work for the first time. ridiculous and disgusting. I may run a contest to give it free to a person who going to have this story shared with the most people on social network. I'll go back to my great amazing experience with Linksys products and service.
