beyondfedup's avatar
beyondfedup
Follower
Oct 04, 2022
Orbi Not Found
I had to do a factory reset on my Orbi CBR40. I am trying to set it up via the Orbi app. I get through the entire thing and then it says that the Orbi is not found. All of the lights on the front are steady blue and the light within is a steady white. When I go into my phone WiFi settings, it says no internet connection. What do I need to do?? I’m ready to drop-kick it into the woods. Is that my only option? Thanks for the help.
1 Reply
  • FURRYe38's avatar
    Did the phone change it's wifi to connect to the new SSID from the CBR during the setup routine?
    I recommend setting up the CBR using a wired PC and web browser connected to 192.168.0.1 or orbilogin.com
