ArtLee
Jun 20, 2017Apprentice
Orbi not ready for prime time?
I bought the RBK50 base+satellite system two days ago and already the system failed. And, I see firmware updates seem to come now and then, which makes me think Orbi is not yet ready for prime time.....
ArtLee
It worked great for 48 hours. My issue is stability.
- st_shawJun 20, 2017Master
I can't tell what you're looking for and what your failure was. But, if by "stability" you mean you want a system with no future firmware updates, then forget it. The system automatically updates and there will be more updates soon.
