Smarcus
Apr 14, 2020Aspirant
ORBi not showing connected devices
Hi, my Orbi is still not showing any connected devices, will Netgear put out a patch to this anytime soon?
Anonymous
Apr 15, 2020factory reset is NOT required
Smarcus
Apr 15, 2020Aspirant
So if not factory reset, what can I do to make it work?
- AnonymousApr 15, 2020
Smarcus wrote:
So if not factory reset, what can I do to make it work?it's probably firmware related.
have you told us about your firmware, as in what do you currently have, last update, etc?
- FURRYe38Apr 15, 2020Guru - Experienced User
Please try a factory reset and setup from scratch with the RBR and RBS.
Smarcus wrote:
So if not factory reset, what can I do to make it work?- AnonymousApr 15, 2020
why is a factory reset considered a cure all???
