Famousunknowns
Jan 01, 2018Aspirant
Orbi not showing up on WiFi device list
Just got my Orbi rbr50 tryed setting it up to my xfinity modem and went through all the setup steps but is not popping up in my WiFi device list. I also tryed bridging the modem but Orbi is still not...
Ddiaz02
Jul 02, 2018Aspirant
Having the same issue. The reset did not do the trick. I notice a recent update and the issue occurred after that. Can anyone help?
Jul 02, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem the Orbi is connected too? Built in router here by chance?
Are you using a custom SSID name when you set up the router?
Did you walk thru the set up wizard to help you install the Orbi?
Any other wifi neighbors near by? If so, how many?
What channels are you using? Try manual channels 1, 6 or 11 on 2.4Ghz and other unused channels on 5Ghz.
Disable MIMO, Daisy Chain and Fast Roaming.
Whats the distances between the router and satellites.
