sneh47
Aug 25, 2019Aspirant
Orbi not working, No Error/Warning lights
Hello
I have had an Orbi system (RBR50 and a satellite) for a year and everything has been fine with the latest firmware. Yesterday I reset my router to see if my performance in a game was related to the router. After that, the system worked fine for the rest of the night (atleast 5 hours).
Ever since today morning, I have been issues with the network not working, so my dad power-cycled the modem and the router. I called ATT and checked the modem, everything is working. I am using the modem directly to send this post and they enabled the wifi on the modem so my house still has wifi.
The issues on my orbi are weird. Everything on the Orbilogin dashboard is fine, no issues. I have reset the router many times. Turned on and off implicit beamforming, mu-mimo. Changed DNS to google. I am able to access youtube on my pc fine but nothing else. Sometimes speedtest or twitch would load. On my phone i was able to go on reddit fine while connected to Orbi wifi but nothing else.
What I feel like is happening, everytime the router was reset, I could go on any website for 20-30 seconds, run a speedtest and then everything just stopped loading except youtube for some reason(could watch any video). I have checked the cat5e cable and its working fine while connected from my modem to my PC. So I am not sure how to troubleshoot this.
EDIT: MY pc is connected to the router via ethernet |||||| I posted this from a reddit thread I made an hour ago
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- sneh47Aspirant
Hi,
My modem is the 5268AC by Arris. I called ATT and put in bridge mode again so I could start testing again with all the possible WIFI channels and disabling the extra features such as daisy-chain and coexistence you suggested but it has the same behavior. I don't think these changes would help in my situation because I am testing on my PC which is connected to my router via Ethernet and still cannot get connection. For some reason Youtube still works fine on chrome yet nothing else will on the PC.
My orbi and satellite are about 45-50 feet apart like it has been for the past year. I have also only 1 wifi neighbor.
Very sad that I spent 350 on this setup and its not working after only a year. I tried calling netgear support but now they want me to purchase gearhead support because I dont have technical support anymore. I guess the Orbi is just bricked and can't route.
Guess you must have bust something in your earlier experimentation. Unfortunately, Netgear's support won't cover that so you are better off here. It is free.
It isn't obvious to me that your attempts at recovery have included the basic restart regime.
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
sneh47 wrote:
...I am testing on my PC which is connected to my router via Ethernet and still cannot get connection.
So what happens on the PC? Any messages?
I'm afraid "cannot get connection" doesn't give us much to go on.
You can help by providing detailed descriptions of what you are doing, where it goes wrong and what messages you see.
