austoonz
Jan 07, 2017Guide
Orbi, OpenVPN and DynamicDNS
I recently purchased an Orbi kit and having OpenVPN on the router is handy (this was on my old router too, so keeping it on there makes it simpler), however... I have own custom Dynamic DNS confi...
AndUrbi
Jan 15, 2017Guide
Exact same problem here. I already have an account with Dyn.com, and the updater is running on one of my computers already. (And the updater for Dyn.com isn't working, as somebody else has already noted in this forum.)
The wording of the popup dialog when enabling OpenVPN makes it sound like it's just a reminder ("please make sure you will do this"), but apparently that's just a poorly phrased error message.
Can the firmware be fixed, or do we need to just replace this with some wwdrt variant when it comes out if we want openvpn support?
markaustin
Jan 18, 2017Guide
Hey there! I wrote that original post about Dyn.com registration being broken. Thank you for the reference. I'm going to take the opportunity to bump this since it's really annoying to not have the dyn updater working!
- DarrenMFeb 03, 2017Sr. NETGEAR Moderator
This is a know issue which we have fixed in the next official release which we plan to release soon
DarrenM
- AndUrbiFeb 04, 2017Guide
DarrenM wrote:This is a know issue which we have fixed in the next official release which we plan to release soon
That's great to hear! A clarification:
Are you talking about (1) the Dyn.com updater not working, or (2) the OpenVPN not being able to be enabled without also using one of the (excessively-feature-restricted) builtin DNS updaters, or (3) both?
Really, fixing (2) would be the most awesome thing, but (1) would at least help in the cases where only a single domain requires management.
In any case, thank you for keeping us in the loop!
- AndUrbiJun 03, 2017Guide
Even with the latest firmware, nothing in the builtin Dyn.com updater will work. I've finally giving up on Netgear fixing this or talking to us about it, and have moved my crucial stuff to a different, more professional-grade device. Ah well.
- burtwilsonApr 25, 2017Initiate
Is there an update for the fix of this VPN issue? It's been almost 3 months and users still cannot activate the VPN server on Orbi unless they are going to use one of Orbi's predefined DDNS services. This product was advertised as having VPN services, but no where in the product literature did it mention that it was restricted only to users with either a static IP or just one of three particular DDNS services. Please provide a date for when the product will be able to perform to the advertised specifications.
- OrbiManApr 25, 2017Luminary
I activate the service, but I found that there is some major downfall, I would say not worth it. The main issue is security concern, there is no way to revoke the certificate or deactivate a user, if anyone have the config file, then that is it, they are free to roam. This is like a single user type of VPN, also I don't know how they generate the key for the VPN or the cert either. I feel that this is a big security risk. The least they could do is include a user name and password for the VPN service.
