jfishburne
May 20, 2018Aspirant
Orbi outdoor satellite range versus indoor satellite range
Hi, I have a large property and I am trying to get wifi from my house out to my barn and up to my pond. I have my router in the house and 1 satellite in the pond pumphouse and 1 in the barn. My coverage/range is not quite enough to be able to use my Arlo cameras. I see that there is an outdoor rated satellite and I am trying to find out if that has a greater range than the indoor satellites. I see that the outdoor satellite has a range of 2,500 square feet, but I haven't been able to find out what the range is for a single indoor satellite.
jfishburne wrote:
I have been chatting with Net Gear's Orbi support. For me they recommended that I use the outdoor rated satellite in the middle (I happen to have power in a central location) and use it as a daisy-chain between my router and my farthest satellite which is about 650 feet from my router. I was getting 1 bar of coverage between my router and that farthest satellite and they said this should fix it. I hope that helps.
I looked at your diagram. If I were you I would just go move satellite 2 to the "possible" location temporarily, and see if it improves satellite 3 (or vice versa). That should give you a clue whether it will work before you buy anything.
One issue with daisy-chaining is that the user cannot control it. The system will decide whether to daisy-chain or go direct to the router, and you can't set it one way or the other. By doing the above, you can also see if the system is stable.
- st_shawMaster
The outdoor satellite provides better WiFi coverage over an outdoor area, because you can place it outside and eliminate walls between the satellite and the client devices. The 5 GHz transmit power is actually slightly lower than the indoor Orbi satellite. I don't think the outdoor satellite will, or is itended to, operate at a longer distance from the router.
Orbi is designed to provide coverage over a large area, not to provide a link over a long linear distance. The best thing for that is a wireless point-to-point bridge with directional antennas on each end.
- TECman51Tutor
Can you recommend one that will work well with the Orbi?
- tsigLuminary
Wouldn't the outdoor unit with wired backhaul get it done?
- jfishburneAspirant
Thank you for the quick reply. I am close to having enough coverage so I am just looking for a way to easily boost what I have a little bit. Attached is a visual of what if looks like. I currently have 1 bar of coverage at the pond and 1 orange colored bar at the barn. So they both work, but just barely. I have power at a somewhat central location in the middle of the attached map and I was wondering if I placed an outdoor satellite there if that would help relay a stonger signal between the router and the barn satellite or if each satellite needs to directly talk to the router itself. Thanks!
Cat5/6 are around 165 feet. CAT6A could go up to 330' feet. Still leaves 70'+ to deal with. :smileyfrustrated:
https://en.wikipedia.org/wiki/Category_6_cable
- tsigLuminary
Not sure where your getting 165' for cat5/6, but that is just wrong.
1000BASE-T (also known as IEEE 802.3ab) is a standard for Gigabit Ethernet over copper wiring.
Each 1000BASE-T network segment is recommended to be a maximum length of 100 meters (330 feet) (however, the length is not a pass/fail criterion as testing the conformance to EN 50173 series standards), and must use Category 5 cable or better (including Cat 5e and Cat 6).
Same place.
Overall, not quite enough for 400 feet which I presume we can agree on. I presume it should work with out too much degradation. It's a stretch thats for sure.
I would look into a directlional AP at the main building and recieve directional AP at the barn area. Might incure more cost this way vs try a burried cable. I would test a cable first. Run on top of the ground for a quick test. If it works then go bury it.
