fade6's avatar
fade6
Orbi Outdoor Time Different
Hello. I have a schedule set for the outdoor LED to turn on/off. However I've figured out that the outdoor is 4 hours off from the actual time. I've verified that the router time is accurate. So, for instance - when the actual time (and verified time of the router) is 9pm EST, the outdoor sat thinks it is 5pm. I figured this out by adjusting the schedule. So in order to have the light go on at 7pm, I've had to set the schedule for 3pm. Anyone know how to get the orbi outdoor time changed?
    • fade6's avatar
      fade6
      Yes, exactly - sorry should have included that
      • FURRYe38's avatar
        So if you factory reset the RBSy while in the same room as the RBR, the time seen on the RBSY is off?
        Something to contact NG support about:
        https://www.netgear.com/support/#
        Blanca_O
        Dustin_V
        I know the RBSY FW is not at the same version level as most current FW for the RBR/RBS. So something maybe out of sync in RBSY FW.
