tewatson60
May 31, 2020Tutor
Orbi overnight speed decrease
Trying to figure out why wireless speed drops while logged off overnight. I routinely get 200+ MBPS all day through the wireless connection...however, after logging the computer off at night, then lo...
Jun 01, 2020Guru - Experienced User
Are wired LAN speeds still good?
- tewatson60Jun 01, 2020Tutor
Modem is a Hitron E31N2V1 (supplied by internet provider), but I can't see how it would matter. The Orbi router handles all DHCP assignments, etc. and the issue is limited to wireless connection.
Tom
- FURRYe38Jun 01, 2020Guru - Experienced User
What is the mfr and model# of this wifi adapter that the PC is using?
If you turn OFF The RBS, does the RBR show the same problem?
hTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).You might update to v16 on the system, factory reset and setup from scratch. https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/true#M89460
