tewatson60
May 31, 2020Tutor
Orbi overnight speed decrease
Trying to figure out why wireless speed drops while logged off overnight. I routinely get 200+ MBPS all day through the wireless connection...however, after logging the computer off at night, then lo...
tewatson60
Jun 01, 2020Tutor
Modem is a Hitron E31N2V1 (supplied by internet provider), but I can't see how it would matter. The Orbi router handles all DHCP assignments, etc. and the issue is limited to wireless connection.
Tom
Jun 01, 2020Guru - Experienced User
What is the mfr and model# of this wifi adapter that the PC is using?
If you turn OFF The RBS, does the RBR show the same problem?
h
You might update to v16 on the system, factory reset and setup from scratch. https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/true#M89460
