bager33S
Jul 31, 2017Aspirant
Orbi pairing issue
When setting up the Orbi, I never got the LED Blue ring on the router. I did have it on the satellite. The signal from the satellite is stronger than the router. Does this mean that the pairing is not correct? Thanks for any suggestions.
Sort By
- justSomeoneAspirant
Look at the firmware issue.
go to orbilogin.com
see if there is a sattelite.
if the firmware is 12.x then you may have to revert the firmware... or if recentlly purchased return unit to store
