ghostfacedkilla
Apr 03, 2020Tutor
Orbi performance with my Macbook - with a solution
When I first installed my Orbi last week I was getting killer performance on my Macbook - 400+Gbps symmetrical over wifi. But over time it has degraded, to 15, then 10, and today it was closer to 6 -...
Apr 23, 2020Guru - Experienced User
I recommend editing out your WAN IP address so it's not posted in public forums.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://community.netgear.com/t5/Orbi/Orbi-Satellite-Drop-Connection-time-to-time/m-p/1890341/highlight/true#M88026
Has a factory reset and setup from scratch been performed since last update?
