serac
Sep 01, 2016Guide
Orbi placement concerns
Having one router / WAP near the edge and the other WAP (satelite) near the middle of the home is a poor layout for optimized coverage. Reminds me too much of single WAP systems this Orbi mesh system...
- Sep 02, 2016
Every home is different but this is our general guide for common house layouts: http://kb.netgear.com/app/answers/detail/a_id/31029/~/where-should-i-place-my-orbi-satellite%3F
The optimal placement does very depending on the layout of the home.
You can experiment a bit to see what works best for you, but there's a good chance you'll find the first place you put the Satellite works great.
Most internet connections have wiring that terminates at the edge of the home. Yes some of the coverage of the router would fall outside the home. Unless you are able to place the router in a more central location (due to internal wiring) there's not much that can be done about that.
Our focus has been on performance with a dedicated wireless band. As we've gone for performance rather than trying to minimise the size of the unit at the expense of performance, we also put a lot of effort into designing Orbi to be aesthetically pleasing. Whilst the router might be tucked away somewhere the satellite could be e.g. in the living room where it could be in the field of vision a lot.
Vinterbird
Dec 17, 2016Star
I have a small 915ft house with a basement around the same size. Would have both the Orbi and Sattelite turned on just be overkill? I went form a Nighthawk X8 to Orbi and have seen a considerable drop in WiFi signal strength in the rooms furthest away.
Mind you, it's a Scandinavian brick house, so the walls are considerably thicker then typical US houses.
Is the Orbi not suited for my type of house?
