Pistol1957
Nov 14, 2016Follower
Orbi Placement
Is is okay to place the Orbi & modem in an enclosed cabinet or closet?
peteytesting
Nov 14, 2016Hero
Pistol1957 wrote:Is is okay to place the Orbi & modem in an enclosed cabinet or closet?
its prob best not to as you may effect coverage and connectivity
- TomMacNov 15, 2016Guru
Any time you add more walls / materials between the main unit and the sat, you'll be cutting down on signal..
That said...in my case a stick built home.... my sat is 40 ft away from the main and it did end up in a closet on a self ( wife didn't want it on her work desk ( happy wife, happy life ))
Tests before and after showed no diiference with transfer rates as I could tell.
