rockywoj
Apr 23, 2018Follower
Orbi Placement?
Can an Orbi AC300 RBK50 satellite router be set on top of a Subwoofer without adversely affecting the signal it emits?
Apr 23, 2018Guru - Experienced User
I would not recommend that. Most sub woofers are not shielded thus the magentic field that comes from the magnet on the driver would probably cause problems. 3 feet minimum distance is recommend between electronic devices and wifi routers.
