mswells
Jan 26, 2019Aspirant
Orbi plus Asus RT-N66U DHCP
I am currently using an ASUS rt-n66u router. Am my better off just using the Orbi alone, or use it with the router. I have all my dhcp stuff...reservations and ranges set up on the asus. Should I jus...
mswells
Jan 27, 2019Aspirant
So the DMZ needs to be set on the ASUS router, when setting the Orbi as an AP....or just to
use both the Orbi and ASUS as routers.
