fnxpt
Feb 10, 2019Tutor
Orbi Port forward random incoming ports
Hi,
I configured my orbi to forward port 8123 to a Synology running an instance of a home assistant.
I configured the port and disabled UPnP and opened NAT, but the port is still closed. I tr...
- Feb 10, 2019
Thank you for your replies.
I manage to discover the issue. The port is open, the problem is on my synology.
My synology is connect with a vpn client, so when its connect I cannot forward the port to it.
Im using this because orbi doesnt support vpn client only server :(
fnxpt
Feb 10, 2019Tutor
The port is closed. So if I connect to the device locally it works. But remotely it doesn’t. What makes me more confuse is that the external port is always a random number instead of the port I configured (same as the internal port)
ekhalil
Feb 10, 2019Master
How do you connect locally? Are you sure that no other ports are needed for this apart from 8123? In this specs I see many other ports being used?
The port you see in the Logs (62.140.132.60:29579) is the source port, the port forwarding that you did in Orbi is for the destination ports, so when device with IP 62.140.132.60 tries to reach port 8123 from WAN it will be forwarded to port 8123 on IP address 192.168.1.17 on LAN and this seems to be working fine.
- fnxptFeb 10, 2019Tutor
- ekhalilFeb 10, 2019Master
Great that you found the issue.
Good luck!
- FURRYe38Feb 10, 2019Guru - Experienced User
Please mark your post thread as solved so others will know for future reference. :smileywink:
