BrettLP
Jan 09, 2018Initiate
Orbi Port forwarding (443) Not Working
Hi all, I'm at my witts end in trying to implement a simple port forward on the Orbi. Effectively, I have Home Assistant (HA) running in my network, and have installed a SSL Certificate and imple...
- Jan 09, 2018Some ISPs block port 443, inbound, to prevent people from hosting web servers.
The Orbi could be using port 443. Unfortunately, I don't think there's any easy way to tell short of disabling any features that could be using it, such as remote management, UPnP, etc.
Can you use a different port, like 22 (SSH), instead of 443?
TheEther
Jan 09, 2018Guru
- fitsnuglyJan 09, 2018Star
Port forwarding 443 works for me and my apache web server. So it's not the Orbi, sorry :-(
